Click for Honda Manuals, Parts and Model Guides!
Results 1 to 6 of 6
  1. #1
    Default Pre CDI Honda B100-1002848 10 HP Coil Craziness
    Hello everyone. I bought a 10 HP Honda B100 Long Shaft Pre CDI last year knowing it had a coil Issue. THE MOTOR HAS POINTS. I have changed the plugs, put a new carb kit in, and replaced two coils. Still no spark. My Mechanic says the coil I need is the Dual Segment Ignition Coil. I have seen this coil it and it has 4 of the Magnetic triangles. Its like two coils on top of each other with two wires coming out of it. I have been looking for another coil without the part number as the coil does not have a part number on it. The Serial Number for the motor is B100-1002848. I have not seen another coil like this on the internet in 6 months. Can anyone help with the name of this coil and a part number? Thank you for anyone who can help. This is what it looks like.
    Name:  Dual Segment Coil.PNG
    PS....I am also looking for the plug for the charging housing for another 10 HP that is the CDI same 80s vintage......Where do I find that so I can charge my battery on my perch boat. Thanks again!
  2. #2
    Default Re: Pre CDI Honda B100-1002848 10 HP Coil Craziness
  3. #3
    Looks like those Coil Assembly's are no longer available, you may find your other parts, your best option is put a "wanted" add on here and other forums or watch ebay for the rest of your life. I have found pretty good luck in the past finding them at boat yards that specialize in the legacy motor market, there is one in Detroit, MI that will pull the parts and ship them to you, I will see if I can find them again.
  4. #4
    [COLOR=rgba(0, 0, 0, 0.87)]Northwestern Boat Co[/COLOR]
    Website
    Directions
    Save
    5.03 Google reviews
    [COLOR=#878787 !important]Boat dealer in Farmington Hills, Michigan[/COLOR]
    Address: 30786 W 8 Mile Rd, Farmington, MI 48336
    Hours: [COLOR=#212121 !important]Opens soon ⋅ 9AM[/COLOR]
    [/COLOR]
    Phone: (248) 356-2477
    Suggest an edit Own this business?
    Know this place?Answer quick questions
  5. #5
    Northwestern Boat Co.
    [/COLOR]
  6. #6
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    3,398
    You can also try www.magnetoparts.com and see if they can rewind it for you.
    Good luck.
Similar Threads
  1. Honda B100 ( not BF100 )
    By chique2016 in forum Honda Outboard Forum
    Last Post: 04-18-2017, 10:48 AM
  2. Honda B100 and Sea foam
    By nlife in forum Honda Outboard Forum
    Last Post: 06-13-2016, 10:59 AM
  3. Honda B100 Sea foam
    Last Post: 06-12-2016, 09:26 PM
  4. help with a honda B100
    By Travis Roberts in forum Honda Outboard Forum
    Last Post: 01-30-2015, 02:36 AM
  5. Honda B100 oil problem
    By eking in forum Honda Outboard Archive
    Last Post: 07-30-2008, 09:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
