Results 1 to 7 of 7
  1. #1
    Default 2005 z200txrd 200 hp hpdi
    Had a load of bad fuel.. cleaned everything in the fuel system out. Engine died on water. Mechanic replaced vst pump and filter..got boat back and it still ran like crap and stalled out..Decided to dive in on my own and learn this engine and pulled everything apart.. cleaned injectors and pulled hp pump apart.. 1 filter was loaded with crystalized crap. Replaced filters/screens and started it up on separated tank of fresh fuel. Ran yds diagnostic software and got and Atmospheric pressure sensor .. code 22 error. Cant for the life of me seem to find out about that on where it is!!! Is it labeled with another name? Map?? Engine does start right up and run but it get surging and will still stall out unless run at higher rpms..changed both LP pumps also..Anyone have an idea?? TYIA
  2. #2
    Default Re: 2005 z200txrd 200 hp hpdi
    It doesn't have a MAP sensor what you looking for is the APS Sensor this one measures the pressure its located on the bottom corner of the VST
  3. #3
    Quote Originally Posted by Tegweni View Post
    Thanks but thats whats confusing me.. that part on the bottom.. its square and black is listed as a relay. Its mounted right under vst.....Is that the same part???
  4. #4
    Here is the part no: 68F-82380-01-00 For the APS sensor
  5. #5
    Thanks much!!!
  6. #6
    Synchronize your throttle valves they should all be closed at idle and your TPS volts should be between 0.48 to 0.52 when you have done this adjust the oil pump arm linkage at idle the arm should touch the stopper . on this model you will take a chance if you bleed it running it on a premixed as the oil pump feeds the vst tank and the manifold onto the cylinders .at idle disconnect the throttle oil pump link arm then move the oi pump arm by hand to its fully open position while at idle to bleed it
  7. #7
    Sorry this was ment to go on another thread.
Similar Threads
  1. 2005 Yamaha 200 hp hpdi
    By Mccullers01 in forum Yamaha Outboard Forum
    Last Post: 04-22-2019, 12:25 PM
  2. 2005 300 hpdi forsale blown up
    By zackfactor in forum Yamaha Outboard Forum
    Last Post: 11-17-2011, 02:28 PM
  3. Sick 2005 hpdi 250
    By cajunfuse in forum Yamaha Outboard Forum
    Last Post: 07-17-2011, 11:11 PM
  4. 2005 yamaha 225 hp hpdi misses at low rpms
    By gamb201 in forum Yamaha Outboard Forum
    Last Post: 01-27-2010, 10:12 PM
  5. 2005 HPDI 200hp
    By capt_slim in forum Yamaha Outboard Archive
    Last Post: 10-13-2007, 12:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
