I bought a new in the box 2017 DF25A in may 2019, It runs fine no complaints but my question is when I hook the rubber cup garden hose thing to flush no water comes out the pee hole, the manual says to start motor and water should come out, I only ran 3 seconds before shutting motor off to avoid damage, is that not long enough for water to find its way? When I hook up the hose to the side plug water does flush the motor but manual says that's for motor not running. The pee hole always works when out on the water or when submerged in a tub but nada when clam shell hooked up?
Any suggestions this is my first post thanks in advance!
