Results 1 to 7 of 7
    Default Barn find: twin 225's with 30 hours
    Helping a friend buy a "barn find" boat that has twin 225s on it. Motors are 2003 and apparently only have 30 hours on them (I'll hook up Dr H to confirm), and the boat has been sitting in dry storage since 2009.
    Aside from obvious fluid/filter swaps, water-pump, valve-adjust etc, racors, new fuel etc. what else would you be worried about if it's been sitting that long? Possible bargain find or run away?
    Sep 2008
    Hague, Virginia, USA
    4,659
    Default Re: Barn find: twin 225's with 30 hours
    2003's with only 30 hours is going to have significant issues. These engines do not take kindly to long set ups. The bearings are all likely dry, so you may want to get some good batteries, pull the plugs, pull the kill switch, and crank them for a while to get oil circulating. Someone else may have a better solution for getting oil to the bearings. When set up and let dry like that, you are also likely to have an issue with the trust bearing. When that fails, the engine is toast.
    Attached is a list of issues with the 225. Note that there are two pages.
    Honda Gripe List_Updated 7_12_19.pdf
    The exhaust tubes should be replaced with the upgraded ones per Honda SB # 56. That SB is too big to upload on this site, so send an e-mail to me requesting a copy of SB #56. [email protected].
    When you change the water pump, closely inspect the mid-shaft bushing and lubricate it. And every time you change an impeller, inspect for wear, or wobble. If that bushing fails, it can eat a hole right in the front of the lower cowling.
    Pull all electrical connectors and check for corrosion - especially those three big ones plugging into the ECU.
    Exercise the tilt/trim and look for leaks around the hydraulic cylinders. The seals have likely dried out. Same for hydraulic steering ram.
    That's top of mind. Hopefully others will kick in with a reply.
    CHawk 25 DLX
    Sep 2008
    4,659
    Also, since you're not concerned with warranty, use 25W-40 FC-W oil - 8.2 quarts with new filter. That will go a long way to saving your thrust bearing.
    And get a Helm shop manual. You're likely going to need it. Be sure to get the one that applies to these earlier engines. It's about $126 on e-Bay, if you can still find one.
    CHawk 25 DLX
    Thanks chawk_man. Will relay the info - sounds like high risk on the thrust bearings. I suspect they will be more inclined to “run away” than celebrate over a bargain find.
    Sep 2008
    4,659
    If you have the right equipment, you can measure the play in the crank shaft by gently prying up the flywheel. Maximum play = 0.0186 inches or 4 mm . With only 30 hours, I suspect that there is no problem with them at this point. And that heavier oil should keep them better protected.
    CHawk 25 DLX
  6. #6
    Jul 2008
    Tauranga New Zealand
    145
    0.4 mm
  7. #7
    Sep 2008
    4,659
    Bobmech - thanks for the correction. Fat fingers strike again.
    CHawk 25 DLX
  1. barn find 2005 Nissan 18hp Fourstroke (NSF18B2).......need advise on what to do
    By bamaboatguy in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-20-2019, 11:28 AM
  2. Evinrude barn find running issue
    By Inoxrob in forum Johnson Evinrude Outboard Forum
    Last Post: 05-21-2019, 12:15 AM
  3. Barn find
    By gwgtn in forum Eska Outboards
    Last Post: 12-23-2017, 04:09 PM
  4. barn find what is it
    By nbsproducts in forum Identifying Model / Year / Horsepower
    Last Post: 11-22-2015, 09:41 PM
  5. Help! Cant find hours meter
    By agoodsi in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 03-24-2011, 04:40 PM
