I have a 1998 mercury 115 2 stroke 2+2 that starts and idles fine but once I start to accelerate and the other two cylinders kick in the engine starts to bog and shake and wants to die at anything above 2,000 RPM. Sometimes it will run fine for a minute and then start to cut out and pick back up again but I can't seem to figure out the problem. The compression is within 5 psi of 120 psi on all cylinders and I have replaced all fuel lines coming from the tank to the motor as well as the primer bulb and the carbs have been cleaned thoroughly with carb cleaner and compressed air. Could it be the stator or fuel pump? Any help is greatly appreciated, thanks.
