This is from the OIS2000 ignition troubleshooting guide at CDI Elevtronics
NO SPARK OR INTERMITTENT SPARK ON ONE BANK:
1. Disconnect the Black/Yellow stop wire AT THE POWER PACK and retest. If the engine’s ignition has spark, the stop circuit has a fault. Check the key switch, harness and shift switch.
2. Disconnect the Yellow wires from the stator to the rectifier and retest. If the engine sparks, replace the rectifier.
3. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to spark properly. This can be caused
by a weak battery, dragging starter, bad battery cables or a mechanical problem inside the engine.
4. Check the stator resistance and DVA output (see Step #13 on NO SPARK ON ANY CYLINDER above). If the power pack has no
spark on one bank and the readings are good, replace the power pack.
5. Disconnect the 4-pin connector on the port side of the power pack and see if the spark returns. If it does spark, check resistance to
see if the Black/Yellow wire is shorted to engine ground. Check to see if the Shift Interrupter switch is located in the circuit where there is no spark.
