I’ve checked out and or rebuilt everything I can think of! Can anyone recommend what else it could be? Electric cos out ok , rebuilt carbs, new fuel pump, all new hoses and replaced tank.They all run great in neutral or on a trailer.-----That is not a meaningful test at all.----Still more trouble shooting to do.
Carborators are completely rebuilt , but thank you anyway!Sorry -----I am not there to see your work.-----But screwed into the bottom of the carburetor float bowl you will find the high speed jet.----Also called an orifice plug.----It is 5/8" long and way in behind that drain plug.-----If plugged that would be one reason for the motor to bog down.-----Or bring the motor over , I can fix it.-----And find out the issue before running the motor out on the lake.-----Say you have a plugged carburetor you risk serious damage to the motor.
