Male Spade Connector on Boat Rocker Switchboard broke off, is there a fix?
Johnson101
I was doing some work on my boat, which I realized that the male spade connector that is connected to my boats rocker switchboard as broken off completly.
I was wondering if there is anyway to fix this without replacing the entire switchboard
any help is appriciated
thanks!
Usually the male terminal is an integrated part of the switch....and they aren't replaceable.
Not having seen your 'switch panel' I can't say if the switch is easily replaced as a separate unit....some can be, some can't be....if you can remove the switch easily then you have to identify and obtain the correct (or suitable) replacement....
It might be possible to take the switch apart and soldier wire or an extension. Sometimes there's an fuse/breaker for each switch and you can attach there (if you know what you're doing). Or you can forget about that part of the panel and duplicate it elsewhere.
