Click for Perkins manuals!
Results 1 to 3 of 3
    Default Would like to add a temperature alarm system to my 4107
    First I had problems with my freshwater cooling system now my raw water system I need an alarm of some kind before my engine gets damaged
    May 2015
    Oregon
    130
    Default Re: Would like to add a temperature alarm system to my 4107
    If you have wet exhaust, there are temp sensors that mount on the hose. Usually when I start an engine I feel the raw water hose/pipe where it exits the engine, before it enters the exhaust. You will feel it become cooler unless you're in water warmer than the air temp. Most people check for a flow out the exhaust after starting.
    Jun 2008
    Island Heights, NJ,
    3,170
    Most problems that appear in one's "fresh water" cooling system are due to a failure or degredation of the raw water system. The big three failure points are:
    1) Plugged/clogged raw water strainer screen (if equipped)
    2) Raw water pump failure/degradation
    3) Plugged/corroded raw water passages ( typically in the elbows)
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
  1. Perkins 4107 coolant system problems
    By Captdoug in forum Perkins
    Last Post: 07-23-2019, 07:47 AM
  2. Temperature Alarm
    By randyjoh in forum Mercruiser Sterndrive Forum
    Last Post: 06-02-2016, 02:35 PM
  3. temperature alarm
    By kostro in forum Mercury Mariner Outboard Forum
    Last Post: 09-13-2015, 12:36 PM
  4. Operating Temperature for 400 Chryslers raw water System
    By wkaufman in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-15-2009, 05:18 PM
  5. Alarm horn and temperature system
    By smaresh in forum Johnson Evinrude Outboard Archive
    Last Post: 10-22-2007, 12:31 PM
