Results 1 to 3 of 3
  1. #1
    Default I.D. plate matching tag on clamp question
    Have a E30RCCE which is the info on the power head plug.It is a long shaft outboard.The tag on the clamp is scraped almost completely off so I cannot get any info from that.Does the power head plug usually show if it is a long shaft since the power heads could go on either one?
  2. #2
    Join Date
    Sep 2010
    Posts
    19,148
    Default Re: I.D. plate matching tag on clamp question
    The CC tells me that it is a 1988 model.----The powerhead plug indicates SHORT SHAFT.----But post some pictures of the motor and the midsection / exhaust housing.---Many here can instantly identify a long shaft motor.
  3. #3
    Quote Originally Posted by racerone View Post
    thanks..Click image for larger version.
ID:	21582Click image for larger version.
ID:	21583I had thought it may have started life as a short shaft and was converted or the original power head was replaced with a head from a short shaft to a long shaft motor.As you can see it has the extention pc on it.
Similar Threads
  1. Throttle bodies not matching
    By 208Adventure in forum Johnson Evinrude Outboard Forum
    Last Post: 06-05-2017, 06:41 PM
  2. CMC PT-130 Tilt and Trim Plate compatibility question
    By FiveStar in forum Johnson Evinrude Outboard Forum
    Last Post: 09-01-2015, 04:02 AM
  3. ignition plate question. 1976 25HP
    By gflaxman101 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-20-2012, 05:45 PM
  4. Yamaha 4hp 4-stroke turning clamp question
    By mkaynor in forum Yamaha Outboard Forum
    Last Post: 10-20-2011, 11:35 AM
  5. 1990 115 Merc Carb amp Jack Plate Question
    By capsboy02 in forum Mercury Mariner Outboard Archive
    Last Post: 06-24-2009, 11:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
