Hi all.
I have a boat with a 2003 Honda 225 with 147 hours. I bought the boat locally but did not do a sea trial which is my biggest regret. Here is the issue. It starts and runs fine but will not accelerate past about 1000 rpm. Top speed is about 10 mph. So far I have replaced all fuel filters. It’s not running away from fuel. It accelerates to about half way on the throttle and won’t increase to full speed. I replaced the ECU since on one cylinder it was not a 5 vet pulse but a constant 5 v. The new ECU fixed that issue. I also put on a new alternator because it was not charging and giving the alarm. This is now fixed. Checked fuel pressure and under idle and full throttle it’s 40 psi. Checked compression in all 6 cylinders and it’s within spec. Does anyone have any ideas? My mechanic and I are stumped. Also no lights on keypad and no error codes via computer check. Any thought would be greatly appreciated
