So I was cruising at 3/4 throttle , and it died , Dead , and would not crank , Like the Battery was dead , Just a little unck , Like it was making the effort ,I took the cover off , Water jacket and top of flywheel , almost too hot to touch , Maybe even was too hot to touch , If I hold my hand firmly on it I started back on the kicker , After a few minutes , I turned the flywheel with my hands, SO I tried to start it , and it started ,Then did the same thing slowed like it bogged down a bit and Died . so I took it back in on the kicker , But right before , I tried again , and it started , So I came in less than half speed and it made it , I felt the Water jacked , and it was much cooler than the first time . I replaced the water pump and much more water comes out the exhaust holes ,Than the old impeller s water flow ,While on ear muffs ,also the old impeller was bent pretty bad . However , When i left the dock , The exhaust holes appeared to be sputtering a good amount of water. My buddy said , Sometimes , If something blocks the water flow, It could overheat , and bind up , but not ruin the engine , What do you guys think , Its running on muffs , I have not taken it back out since , Other thing is , I poured about 1 and a half cups of sea foam in the gas ,
