MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 10 of 10
  1. #1
    Default Mercury 40 hp power source to charge batteries????
    Hi Iím new here and have some questions if anyone can help me . I currently have a 1999 60 hp 2 stroke mariner outboard on my boat that has power trim and electric start. I got a opportunity to get a 2006 40 hp 4 stroke mercury outboard for dirt cheap. This motor does not have electric start or power trim . Iím wondering what will gas economy be like compared to my 2 stroke engine ? Also my main question would be that I have a battery on my boat to run my electronics . How can I maintain my batteries with the 40 hp mercury outboard? The only wires coming out of the motor is the shut down wires for the switch. I seen some wires under the hood that are capped off. Anyone know what wires I can use ? Thanks for the help
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,418
    Default Re: Mercury 40 hp power source to charge batteries????
    Get a wiring diagram and see where the wires from the stator (to charge the battery) go. Someone must have cut them off since all modern motors of that size have a charging circuit.
    Jeff
  3. #3
    Quote Originally Posted by fastjeff View Post
    Jeff
    Would anyone happen to know know where I could find a tech manual for a 2006 mercury 40 hp 4 stroke ? Need to know what wires are for charging circuit and possible the rpm gauge hook up? Thanks
  4. #4
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,710
    post serial #
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  5. #5
    Quote Originally Posted by faztbullet View Post
    post serial #
    Serial number is 1C033156
    model is 40ML 4STK
  6. #6
    On my '92 Merc 40, the 2 wires from the stator that charge the battery are yellow and go to a voltage regulator; no guarantee that yours are the same color.
  7. #7
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,710
    Your parts breakdown shows no rectifier.....
  8. #8
    fazbullet, good catch; if you are responding to me; in my shop manual by Brunswick Corp for my '92 Merc 40hp (bought the manual at the same time, lucky I did), the electrical schematic drawings show a rectifier but no voltage regulator; however, in the written documentation, there are tests for a rectifier and a voltage regulator - go figure; shortly after I bought the motor in '92, I had some sort of electrical problem (maybe dead battery) and the dealer replaced the rectifier with a voltage regulator - two yellow stator wires going into it; no issues since. However, there is a mystery component behind some gray foam padding I haven't looked into yet - see pic; the new voltage regulator is just below that.
    OK, my bad, you are replying to the original poster.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  9. #9
    yes I don’t believe it has a rectifier . There are 2 yellow wires that come from the stator that are yellow and are capped off. Will
    i need a rectifier to charge my batteries? Also would you know what wire is for the tach? Thanks
  10. #10
    The 2 yellow wires coming out of my stator go to a voltage regulator as I have indicated above; from there, out of the voltage regulator come wires involved with charging the battery; maybe you could check your yellow wires to see if there is any voltage coming out of them. I thought I saw somewhere that a 9amp stator is put into outboards that don't have electric start and consequently no battery. My stator is a 16amp stator.
Similar Threads
  1. power source
    By byron in forum Boat Electrical Systems
    Last Post: 12-01-2018, 07:06 PM
  2. Batteries not holding charge
    By dollie_blue in forum Volvo Penta Gas Archive
    Last Post: 07-21-2009, 10:03 PM
  3. Tilttrim switch power source DT115 1986
    By alan in forum Suzuki Outboard Archive
    Last Post: 03-12-2009, 02:55 AM
  4. Low Volts batteries wonbt seem to charge
    By dhogencamp in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 07-05-2007, 07:34 AM
  5. Power source coil
    By buddyruff in forum Suzuki Outboard Archive
    Last Post: 05-06-2007, 03:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
