Results 1 to 2 of 2
  1. #1
    Default 1988 2.3 litre sohc rust particles in manifold past thermostat
    I have a 1988 bayliner capri with 2.3 litre sohc engine. Ive been having problems with it overheating, i already replaced the water circulating pump, now i just went to remove the thermostat to replace that and there is rust chunks packed in what i think is the manifold. Any suggestions what the cause of this would be, and also the best way to clean it out? Is there away to reverse flush this?
  2. #2
    Join Date
    Apr 2009
    Location
    Long Island, NY,
    Posts
    180
    Default Re: 1988 2.3 litre sohc rust particles in manifold past thermostat
Name:	4.3 Center Riser Exhaust Conversion.jpg
    It sounds like you need a new exhaust system (exhaust manifold + elbow). They do rot out and have to be replaced. I've done mine 3 times in salt water, first with the OMC batwings one piece exhaust for the V6 (3 sets including the ones that came on it) and the last one I converted to the center riser 2 piece units because the batwings are long since NLA.
Similar Threads
  1. 1988 Cobra OMC Inboard 2.3 Liter SOHC Engine fit 1978 starcraft super sport
    By Vas Sallini in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-12-2015, 09:16 AM
  2. Rusting intake Manifold....BAD rust
    By lgdpt in forum Volvo Penta Gas Engine Forum
    Last Post: 10-23-2012, 01:06 PM
  3. Exhaust manifold aq120b 4 cyl sohc
    By sunliner in forum Volvo Penta Gas Archive
    Last Post: 07-31-2008, 12:49 PM
  4. Manifold Clogged due to Rust
    By Don Jordan in forum Volvo Penta Gas Archive
    Last Post: 08-23-2007, 12:51 AM
  5. Rust on intake manifold Mercruiser 57L
    By jamison in forum Mercruiser Sterndrive Archive
    Last Post: 05-24-2006, 04:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
