1990 force 50hp spun prop
Taylorls2009
Hey I have confirmed my prop is spun, I removed the hub, any suggestions on where to get a replacement hub. I am
having a ton of trouble finding the proper replacement. Also once I do find one any suggestions on the reinstallation. I removed it using a c clamp and some lubricant. I know I obviously don’t want to lube it on the way back in with regular lubricant, possibly a spray glue or something of that nature? Any help would be appreciated.
hub
brass 14 spline with pin and and snap ring grove
thanks,
Taylor
Your best bet!!
Take it to about any Marine dealer or boat sales, even West Marine.
They usually have a prop shop they deal with.
O try these places.
Marysville Propeller, Millers Island prop repair, Michigan Propeller
You'll need at least a 20ton press to reinstall the hub.
It needs a lot if pressure to put it back.
