Results 1 to 5 of 5
  1. #1
    Default 1960 Chris Craft Paragon 25XE rear seal
    Hi, I have a 1960 Chris Craft Capri with a 283 flywheel forward engine and direct drive paragon 25XE manual transmission and an have searched for days for a part number for the rear output shaft seal. If anyone could help direct me to a parts catalog or knowledgeable parts supplier I would greatly appreciate it.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,986
    Default Re: 1960 Chris Craft Paragon 25XE rear seal
    check with the folks at Hale marine, in VA.....they can fix nearly any marine gear and have been around a long time....
  3. #3
    Thanks Makomark, I called them and they can't get one but they were very helpful and gave me some good tips.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,886
    Ayuh,...... Mic up the shaft, 'n seat, then call Baum Bearing, 'n iron works in Nebraska,..... Lincoln I think,....
    Give them the dimensions, 'n they'll most likely have one to fit,....
    I use them for alotta can't be found seals for all sorta equipment,..... 'n they've never let me down yet,....
  5. #5
    Thanks, That is the route I will go. I have a few contacts close to home but will definitely give Baum Bearing a call if i can't sort things out.
Similar Threads
  1. Switching ROTATION on a PARAGON P300 Trans: '1979 23' Chris Craft
    By terrybrown95919 in forum Chris Craft Engine Forum
    Last Post: 04-27-2011, 10:09 PM
  2. 272 Rear Main Seal
    By dave_kapica in forum Ford Interceptor Marine Engine Forum
    Last Post: 01-06-2010, 04:21 PM
  3. 1960 283 chris craft oil pump
    By tombrancheau in forum Chris Craft Engine Forum
    Last Post: 10-01-2007, 08:48 PM
  4. Shift mechanism 1960 Sea Skiff 283 flywheel forward Paragon manual
    By alarik in forum Chris Craft Engine Forum
    Last Post: 08-18-2006, 11:04 AM
  5. Transom seal pre1967 chris craft OMC 265hp
    By jim arpey in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-06-2006, 02:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
