Results 1 to 6 of 6
    Default 1960 Chris Craft Paragon 25XE rear seal
    Hi, I have a 1960 Chris Craft Capri with a 283 flywheel forward engine and direct drive paragon 25XE manual transmission and an have searched for days for a part number for the rear output shaft seal. If anyone could help direct me to a parts catalog or knowledgeable parts supplier I would greatly appreciate it.
    Sep 2008
    Maryland - USA
    8,211
    Default Re: 1960 Chris Craft Paragon 25XE rear seal
    check with the folks at Hale marine, in VA.....they can fix nearly any marine gear and have been around a long time....
    Thanks Makomark, I called them and they can't get one but they were very helpful and gave me some good tips.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,965
    Ayuh,...... Mic up the shaft, 'n seat, then call Baum Bearing, 'n iron works in Nebraska,..... Lincoln I think,....
    Give them the dimensions, 'n they'll most likely have one to fit,....
    I use them for alotta can't be found seals for all sorta equipment,..... 'n they've never let me down yet,....
    Thanks, That is the route I will go. I have a few contacts close to home but will definitely give Baum Bearing a call if i can't sort things out.
  6. Default Re: 1960 Chris Craft Paragon 25XE rear seal
    Hello, we should be able to assist you with ordering the part you need. Give us a call at fantastic finishes at 330-273-8291
  1. Switching ROTATION on a PARAGON P300 Trans: '1979 23' Chris Craft
    By terrybrown95919 in forum Chris Craft Engine Forum
    Last Post: 04-27-2011, 09:09 PM
  2. 272 Rear Main Seal
    By dave_kapica in forum Ford Interceptor Marine Engine Forum
    Last Post: 01-06-2010, 03:21 PM
  3. 1960 283 chris craft oil pump
    By tombrancheau in forum Chris Craft Engine Forum
    Last Post: 10-01-2007, 07:48 PM
  4. Shift mechanism 1960 Sea Skiff 283 flywheel forward Paragon manual
    By alarik in forum Chris Craft Engine Forum
    Last Post: 08-18-2006, 10:04 AM
  5. Transom seal pre1967 chris craft OMC 265hp
    By jim arpey in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-06-2006, 01:27 PM
