Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2018
    Location
    Melbourne, Australia
    Posts
    29
    Lightbulb 2000 Johnson 70HP VRO/OMS issues - Convert to standard fuel pump?
    Engine= 2000 Johnson 70 hp Model= VJ70VLSIS
    Just purchased a boat knowing it had some issues with the fuel pump. It appears something has gone wrong with the OMS/ VRO it was filled the carburettors with pure oil. What would or could cause this?
    What is the process of converting it to a standard fuel pump? More specifically Once current fuel pump removed what happens to the wiring? Remove it?
    Does this remove any other safety features (Over heat etc?)
    Appreciate any help!
  2. #2
    Join Date
    Sep 2010
    Posts
    19,190
    Default Re: 2000 Johnson 70HP VRO/OMS issues - Convert to standard fuel pump?
    Vent on the oil tank plugged ?-----Oil tank mounted above the motor ?
  3. #3
    Join Date
    May 2015
    Posts
    2,133
    Somebody pulled the fuel line off to try and run the carbs empty? Air leak on the fuel side of the pump?
  4. #4
    Join Date
    Aug 2018
    Location
    Posts
    29
    Quote Originally Posted by racerone View Post
    Hey Racerone
    The tank is not above the motor. However today i noticed the tank has what looks like an outlet/ return that was capped off. This cap was cracked and fell off when i touched it. See below photo.
    Could this cause the issue?
  5. #5
    Join Date
    Aug 2018
    Location
    Posts
    29
    Thanks flyingscott today i noticed the tank has what looks like an outlet/ return that was capped off. This cap was cracked and fell off when i touched it. See below photo.
  6. #6
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,785
    (VRO Changeover Judgement Call)
    (J. Reeves)
    The VROs first came out in 1984 and have been upgraded quite a few times. In my opinion, back around 1988, they had perfected them but I think that they were upgraded even more since then. As long as the warning system is operating as it should, I feel quite at ease with them.
    Some boaters have voiced their thoughts such as "What if that overpriced plastic horn should fail while I'm under way for some reason, and the VRO decides to fail five minutes later?" Obviously that would result in a big problem which really brings their fears into view.
    The word "ease" is the key word though. If one has the slightest feeling of being ill at ease with that setup, then they should take the route they feel more at ease with. A judgement call each individual would need to make on their own.
    (VRO Pump Conversion To Straight Fuel Pump)
    (J. Reeves)
    You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup (and fuel restriction warning if so equipped) by doing the following:
    1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
    2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
    3 - Mix the 50/1 oil in the proper amount with whatever quantity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
    That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. VRO Replacement W/T Standard Fuel Pump?
    By jprevat in forum Johnson Evinrude Outboard Forum
    Last Post: 05-03-2019, 11:14 AM
  2. 1989 70hp Evinrude vro conversion to standard fuel pump
    By Rcatron2 in forum Fuel / Oil Mixture Ratio
    Last Post: 01-02-2019, 01:53 AM
  3. 91 johnson 120 v4. vro / standard fuel pump swap.
    By ChrisQ in forum Fuel / Oil Mixture Ratio
    Last Post: 04-05-2016, 12:34 AM
  4. Replacing VRO fuel pump on Evinrude 130 HP with standard fuel pump
    By Topkick8 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-03-2015, 09:07 PM
  5. convert to standard rotation?
    By buick430 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 03-13-2013, 10:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
