Results 1 to 2 of 2
  1. #1
    Question 2008 F90 died and wouldn’t restart
    Started with one turn of the key the ran out about a mile at full throttle before engine just died as if I’d turned the engine off. Limped back to dock with electric motor and on the 30
    minute run back tried several times to restart with no luck. Got home, pulled fuel rail and full. Pulled plugs and they look fine but changed them out for the hell of it. Only other thing I did was change out a quick connect on fuel line to motor. Turned key and engine started first time. Any guesses on what is going on
  2. #2
    Join Date
    Aug 2016
    Location
    Boston, MA USA
    Posts
    141
    Default Re: 2008 F90 died and wouldn’t restart
    Possibly a faulty neutral safety switch. Maybe water is getting into the control innards.
    2011 Yamaha F50 TLR
    2010 G3 V167C (deep V aluminum hull)
    Boston, MA USA
Similar Threads
  1. 5.0 MPI died at cruise speed wont restart
    By Russ325 in forum Mercruiser Sterndrive Forum
    Last Post: 05-07-2015, 02:40 PM
  2. 2008 6.2 died suddently
    By tugwood in forum Mercruiser Sterndrive Forum
    Last Post: 06-14-2014, 07:16 PM
  3. Suzuki DF250 - motor died - wont restart- <><
    By Matt Raymond in forum Suzuki Outboard Forum
    Last Post: 10-16-2012, 10:29 PM
  4. Engine died - Will not restart
    By buddsy in forum Chrysler Force Outboard Forum
    Last Post: 08-08-2011, 09:39 PM
  5. 73 Evinrude 18hard shifting died and wonbt restart
    By ReelMeister Al in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2003, 09:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
