Click for Volvo Penta manuals!
Results 1 to 3 of 3
    Default Volvo penta power issues
    Right let's see if anyone can help, we have a boat with 2 AD41D engines, one engine is fine, the other however will not rev over 1400rpm, we've had the turbo done, the injectors and injector pump done, the fuel polished, lines cleaned, ant ideas? At wits end! Thanks.
    May 2015
    Oregon
    119
    Default Re: Volvo penta power issues
    I'd do a compression test. One or two cylinders might not be giving their share of power from a ring or valve problem. Could there be some intake air restriction the other engine doesn't have? I believe that engine has an aftercooler. It may need cleaning.
    Many thanks for the advice, I will.show my partner, it's really appreciated
  1. Need Help, Volvo Penta 4.3GL Issues...
    By Dioc_V in forum Volvo Penta Gas Engine Forum
    Last Post: 08-04-2014, 01:07 PM
  2. volvo penta 280 cooling issues
    By ALLTITUDE in forum Volvo Penta Gas Engine Forum
    Last Post: 08-16-2010, 03:07 PM
  3. Volvo penta 180 having issues with sterndrive
    By rivahgurl in forum Other Outboard Motors
    Last Post: 05-29-2009, 03:08 PM
  4. Volvo Penta Starting issues
    By davis_j in forum Volvo Penta Gas Archive
    Last Post: 08-29-2007, 12:10 AM
  5. Volvo Penta 43 gl starting issues
    By Calder Lewis in forum Volvo Penta Gas Archive
    Last Post: 06-20-2006, 11:48 AM
