I cannot configure the throttle rod, drum, and opener properly. One end of the rod sits in a hole on top of the carburetor and the other end comes up through a hole in the throttle opener. But the throttle opener and drum are independent of each other so that when the throttle handle is turned, the cables move the drum back and forth but this motion is not transferred to the carburetor. It seems as if the throttle drum and opener need to act as a unit if the motion of the drum is to be transferred to the carburetor. Any suggestions?
