Results 1 to 17 of 17
    Aug 2019
    Australia, Near Sydney
    4
    Question 0585023 Temperature Sensor Evinrude Johnson OEM 0585023
    From Australia
    I believe this switch needs changing.
    OEM 0585023
    Evinrude Elan, 1995-6, BE35QLEDC
    Need help or suggestions for alternatives.
    Can not find it anywhere..
    many, many thanks.
    Default Re: 0585023 Temperature Sensor Evinrude Johnson OEM 0585023
    Go to thread started 2019-07-16, Obsolete temperature switch, I've replaced it with a starboard single wire switch, it did the job.
    Feb 2001
    Central West Florida
    15,780
    Quote Originally Posted by Northern River View Post
    There'ya go..... Spread the word!
    We occasionally have questions. If you fail to answer, it may affect ours.
    Quote Originally Posted by joereeves View Post
    You're pretty quick Joe, the beauty of the thing, question from Québec Canada, answer from Florida in the States and it ends up in Sydney Australia. Now ain't that something.
    Feb 2001
    15,780
    The world started getting smaller very fast right around 1980. I'm in Florida, my son is in Texas... He might as well be next-door. Yep, that's something.
    Quick??... I didn't notice that time gap. Ha, two minutes! Like I was waiting on your doorstep.
  6. #6
    The more I exchange with you the more I would like to meet you and racerone for a cold pint, I heard the Australians like it too!
  7. #7
    Well I went into the archives and did not find it for July 16, is our Australian friend going to find it?
    http://www.marineengine.com/boat-forum/showthread.php?457663-Obsolete-temperature-switch-what-are-the-options&goto=newpost
    Tried to copy the link from my Email but does not seem to work?
  8. #8
    Aug 2019
    4
    I can not find it.
  9. #9
    Feb 2001
    15,780
    What is that you two are looking for?
  10. #10
    Looking for the thread started July 16 2019, Obsolete temperature switch what are the options
  11. #11
    Found it dated August 14 2019
  12. #12
    Feb 2001
    15,780
    Yeah, I was looking at that yesterday and wondered if you were in error about the date. I copied your hyperlink, pasted it in the Internet command window [ENTER] and that brought it all up for me. Glad you found it... . it's that Canadian Beer that keeps changing the dates!
  13. #13
    Well that's the way to find a thread easily! So now our Australian friend should find it easily by entering the hyperlink in a search engine, thanks
  14. #14
    Aug 2019
    4
    Okay, here is the work around, this unit has the quick start, black and white and sensor Brown blue. We can disconnect the Black White Quick Start, and use the Brown blue sensor (temperature) only. The CDI will work even if the 0585023 is failing. There is no need to use the quick start according to experts, I will update on using an alternative to the 0585023. Also, when the Black White Quick start line is cut, just ground it to the cylinder head, this will over ride the quick start system. I am also buying a Sensor switch without the quick start line, this ensure we have essential outer block heat sensor working. Will update when I have more. I was thinking that we could get a similar sensor and just connect it to the wires.
  15. Default Re: 0585023 Temperature Sensor Evinrude Johnson OEM 0585023
    If anyone is in need of these, we have a few in stock.
    Houseboat & Marine Services, Bullhead City, AZ
  16. #16
    Aug 2019
    4
    Quote Originally Posted by Houseboat&MarineServices View Post
    Yes I am at [email protected]
  17. #17
    Sep 2010
    18,181
    You must realize that there are many similar switches.-----The wires attached to them are different.-----That gives them a different part #.-----Need to cut / solder wires ETC.-----A good boat shop will help you.-----Online parts sellers do not know what fits what !!!
  1. How to get out temperature sensor?
    By iknowaaron in forum Johnson Evinrude Outboard Forum
    Last Post: 08-20-2018, 09:24 AM
  2. Engine Block Temperature Temp Sender VS Temperature Sensor?
    By taymag in forum Mercury Mariner Outboard Forum
    Last Post: 08-17-2017, 09:19 AM
  3. Temperature sensor
    By Elkmontbrown in forum Mercury Mariner Outboard Forum
    Last Post: 01-01-2017, 03:17 PM
  4. Temperature Sensor Removal
    By Greaseball04 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-01-2007, 03:45 AM
  5. KAD 300 Temperature Sensor
    By jeremy rudge in forum Volvo Penta Diesel
    Last Post: 12-31-1969, 08:00 PM
