Results 1 to 5 of 5
    Default 1996 E-tec 200 floods too easy
    Guys
    Just bought the damn thing and really struggling. Went to the lake for the first time and she flooded when i tried to start. Previous owner said dont connect gas line until boat is in the water and the motor is level. if you dont follow these instructions she will flood. no way this is right. appreciate any tips or advice to get this right. Note: the boat was converted to premix gas a few years back, so no oil tank onboard.
    Gene
    Sep 2010
    19,431
    Default Re: 1996 E-tec 200 floods too easy
    Model # of your motor ?????----An E-tec was not marketed in 1996 model year.------An E-tec can not be run on mixed gas !!----I doubt that an E-tec will flood.------Something is wrong here.
    Quote Originally Posted by racerone View Post
    Really wrong!
    The motor housing was painted at some point and has an etec logo on it. let me get back to the boat and get the model number for you. sounds like might have two issue LOL
    Sep 2010
    Jersey Shore
    5,943
    Quote Originally Posted by Gene Gene Dancing View Post
    This is a carbed engine in 1996. squeeze the fuel primer, does it get hard and stay hard with the engine off? No? Pull the pulse limiter line and squeeze the primer, does fuel pour out of the pulse line? Yes? you need a VRO pump.
    This will flood the engine and wreck the crank and piston if the gas is not premixed.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  1. It floods easy
    By Kirk d in forum Identifying Model / Year / Horsepower
    Last Post: 07-08-2014, 06:07 AM
  2. Carb floods
    By frank63 in forum Mercruiser Sterndrive Archive
    Last Post: 06-13-2009, 10:11 PM
  3. Force 15 floods out
    By scott wolfley in forum Chrysler Force Outboard Archive
    Last Post: 07-23-2008, 06:36 PM
  4. 135 hp floods easily
    By Bev in forum Johnson Evinrude Outboard Archive
    Last Post: 07-03-2007, 06:48 PM
  5. Engine floods out
    By marv in forum Archive 2003-2009
    Last Post: 09-04-2002, 02:54 PM
