Click for Volvo Penta parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default Help - 4.3GL steering got stuck to left most position - right turn broken
    Got a 96 boat with a 96 4.3 GL motor and dual prop leg. Was out on the water today and kids wanted to create a whirlpool so I had the wheel cranked to the left most position and was going around a few times. When done I went to turn the wheel to straighten out but nothing changed - the leg was still at the left most position. I turned off the engine and lifted the leg and I could push the leg to the right but once it started it would again shift to the left most position. I found that if I pushed the leg to the middle, the steering wheel still turned the leg to the left but if I turn the wheel to the right nothing happens.
    Would really appreciate some advice to what I did and how to fix. Thanks
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,910
    Default Re: Help - 4.3GL steering got stuck to left most position - right turn broken
    Ayuh,..... Sounds like a broken steerin' cable, or possibly the helm,.....
Similar Threads
  1. Replies: 5
    Last Post: 12-01-2016, 05:48 PM
  2. Force 50 Won't Turn Left or Right
    By meighkee in forum Chrysler Force Outboard Forum
    Last Post: 07-07-2015, 07:38 AM
  3. Replies: 5
    Last Post: 12-02-2012, 01:00 PM
  4. 1972 Merc 80 HP won't turn left or right
    By 69 Whaler in forum Mercury Mariner Outboard Forum
    Last Post: 05-22-2011, 06:41 AM
  5. High speed boat will not turn left
    By chris_454 in forum Mercruiser Sterndrive Forum
    Last Post: 01-25-2010, 06:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
