99 optimax starting issue
whenderson88
I have a 99 150 optimax. My air compressor bracket broke and I replaced the compressor. Now here is the problem. My boat will crank on the muffs every time. It will crank when u first put it in the water but once u start it and run it down the lake when u kill it will not start back. It doesn’t even hit like it’s not getting any fuel or spark. U can take the cowling off or u can trim the motor all the way up out of the water then it will hit about 3 times then crank up. It will do this every time. The prop had to be all the way out of the water or the cowling off. So I think it’s a back pressure issue building up through the prop exhaust I just don’t know where to start. Any ideas?
