Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 2 of 2
    Default NSF18B2 Compression Test
    Planning to do a compression test on an NSF18B2 with electric start. I've watched a lot of videos and read some forum posts and it seems like the steps are:
    1. make sure battery is fully charged
    2. run the motor till its warm and then run gas out
    3. pull off the kill switch lanyard
    4. remove both spark plugs
    5. put compression tester into spark plug hole
    6. press electric start button and get reading on compression tester
    7. repeat 5 and 6 for other spark plug hole
    Is this correct?
    Also, I'm not clear on whether I need to do something with the spark plug wires. I've read a lot of stuff about sparks jumping and damaging wiring and don't want that to happen.
    Mar 2010
    Hamburg, NY, USA
    2,553
    Default Re: NSF18B2 Compression Test
    That should be fine. Remember that that motor has starting decompression, so at RPMs below say 500, your readings will seem low. Expect maybe 71 psi. At RPMs around 1000, the decompressor disengages, and you get full compression, about 135 psi. You can also remove the EX rocker to get full compression for testing, but then you will need to reset valve lash after testing.
    Plug wires are no issue. No wiring will get damaged.
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
  1. Compression test
    By adam_g in forum Mercruiser Sterndrive Archive
    Last Post: 11-15-2007, 10:31 AM
  2. Compression test
    By jjdluz in forum Yamaha Outboard Archive
    Last Post: 10-17-2007, 02:10 AM
  3. Compression Test Help
    By jacobmorin in forum Mercury Mariner Outboard Archive
    Last Post: 04-20-2007, 11:22 AM
  4. Compression test
    By merlin in forum Yamaha Outboard Archive
    Last Post: 08-01-2006, 09:23 AM
  5. Compression test
    By Dan Gavin in forum Outboard motors archive 2000-2004
    Last Post: 07-01-2002, 05:50 PM
