I think your meter may be giving you a false reading, even at a 40 A load a belt should not slip
do you have a 'ground' wire between the alternator case and the engine block?
you close to NJ?
I do have 2 batteries. At first I just ran the alternator wire to battery 1 but then realized that battery 2 would not charge if hooked up that way
Correct!
so I switched it to the solenoid so it would charge on either both or 1 or 2.
It's best to NOT select BOTH/ALL when charging.
You will want the alternator to sense only the battery that is being charged.
(see ** below)
It makes sense not to run them on both other than in an emergency situation
Correct again!
but other than a portable battery charger how do you charge battery 2 if the alternator is not connected to the solenoid and just to battery 1?
If managing your batteries manually, you will select one bank or the other.
** Or...... install an ACR or a VSR and let it do that for you.
BTW it had the alternator issue all along when it was hooked to battery 1 only.
In a 12 vdc system, you will have a Positive and Negative sides only...... (technically, although the term is used loosely, there is no ground in a 12 vdc system).
The charge lead from the alternator will connect to the "common" cable terminal at the starter motor's solenoid.
The MBSS (main batter selector switch) will determine which battery you crank from, which battery will receive the charge rate, and which battery powers the hull harness.
Also, if this is what they call a single wire alternator, it is most likely a Delco 10si.
A 105 Amp 10si will cut back on the charge rate quickly..... in other words, it is unlikely that this alternator will produce 105 Amps.... at least not for any duration.
Going to the #8 charge lead was a good idea.
However, you will also want to increase the size of the short alternator-chassis-to-engine-block Negative cable.
As for battery choices, you will want a good cranking battery on MBSS #1, and a bank of Deep Cycle batteries on MBSS #2.
Good cranking amps for #1, and a large amount of Amp Hours for #2.
Either MBSS selection will draw/charge from/to the bank that has been selected! In other words, all 12 vdc demands will be taken from the selected battery bank.
Crank from #1, warm up engine and charge #1.
Then switch to #2 and go out boating.
This keeps the #1 starting bank in Reserve, as it should be.
An exception to this would be a main engine bay bilge pump's float switch.
To power this float switch, you will connect it directly to the rear MBSS terminal #2, of which will be directly connected to your House Load Batt Bank (of large Amp Hour Deep Cycle batteries).
Doing this will allow you to turn the MBSS OFF when you leave the boat unattended in the water, and will prevent an accidental power shut-off to the float switch.
