brettmarl
2@BF225's. Port has 125 hrs, Stbd has 555 hrs. Last gear oil change was 100 hrs ago. Using Merc SAE-90. Stbd comes out 'well loved' and black, Port looks like it did on the day it went in.
Port also had maybe 1mm layer of shavings on plug which seemed insignificant and I assume normal for a newer engine settling in. Stbd plug was clean.
Wouldn't you expect port gear oil to be the same as stbd? Or is the dark stbd color bad-mojo?
