2004 BF225 1400 HRS motor runs like new was just coming in from a 3 hr ride all was good then BOOM shutdown.
I have volt meter and know how to use it, I pulled cowel and see 13 volts to the main starter wire.
I check all fuses on starboard side all good. but no power to fuse bank. Trim also dead from both rocker switch and and dash switch.
The ignition switch does nothing 100 % dead.
Where should I check voltage next?
Battery switch and Battery supply wires look great all clean and tight.
I have some tools and a volt meter but stuck down on big pine in fl keys please add suggestion if you want to help a guy out.
Thank you.
P.S. been reading this forum for years and saved me lots of time and money Thanks Honda dude "mike"
Thank you.
