I have a 2000 E115 Ficht that have run very nicely with no problems until;
Could anyone help me identify this relay (function – wiring and so on)?
Or better, anyone having the wiring diagram for the starter system or even better the complete?
If anyone could give me an idea of what the problem is, that would be the absolute best
You have to excuse my writing here as I am a Norwegian. Really hope somebody can help me out here.
Thomas
- I replaced a broken starter with a used starter from a 2003 model (same BRP part number)
- After this change, the motor started at first attempt (always had to crank twice before), and easily on the next approx. 3-4 attempts
- Then suddenly the motor was completely “dead”, it would not tilt (up or down) nor crank.
- Found the fuse number 7 (Key Switch, EMM, Accessories) broken and replaced it.
- Then the motor started easily once. But on the second attempt, it did not. Fuse ok, tilt ok – but again no cranking.
- Then I started to measure from the key switch and backward - solenoid assy a.o. All seems to be OK until I came to a standard 5 pin relay placed outside the power distribution panel (where most relays are placed together with fuse holders). It is placed close together of what I believe is the main relay - see attached drawing where the relay/connector is marked yellow. As I do not have a wiring diagram, I do not know the function/purpose of this relay, but I believe it has some safety or assistance function? As I do not have any wiring diagram it is quite impossible for me to identify. The relay is marked yellow in the attached drawing i found on net.
- In to the relay is going a yellow w/red stripe cable (start signal), and from negative (pos 86) there are connected two cables, a gray w/ black striped wire and a darker gray or light brown wire.
- I measure that there is no earthing/ground from the relay when I try to start. I have tested to connect pos 86 (neg) directly to batt negative – and then the starter crank while turning the key.
Thomas
