easyvictor
I've got a '98 15 hp Johnson, starts great and idles fine, but the top end is a big sluggish and has intermittent bursts of power. I pulled the plugs, and the while the bottom cylinder plug looks nice (clean, tan), the top plug is black with wet oil residue. I swapped the plugs, and again the bottom was clean and top was dirty. So it doesn't appear to be a plug problem. I tried pulling the lead off the top cylinder while running and it was sparking to the block and the engine ran rough, so I do think the cylinder is firing. I'm running NGK plugs. What could cause this? Thanks.
