1993 Force 70 horse power ignition timing specs
RicardoMarine
Gold Medal Contributor
I'm helping another forum member with an issue on his '93 70 hp Force.
I would like to know the specs on the ignition timing, from BASE timing on up to full-in.
Give me a 2 stroke motorcycle, snowmobile, chain saw or other 2 stroke engine, and I am in my comfort zone.
However, I don't typically mess with the 2 stroke outboard engines.
Thank you in advance!
This has the T-bolt ignition system. Hence, the static timing (cranking) should be set to 32 BTDC which translates to 30 BTDC dynamic.
