This Honda is about to drive me to drink. I have a pair of 225s. This particular one has been "upgraded" to the new ecm and heated o2 sensor. Don't believe that this has any bearing on my issue though. The oil light on my tach keeps going off, giving me the steady buzzer and cuts back the rpm. i snipped the wire (pink wire)to the low oil pressure sensor. i thought that had fixed my problem until i took it out for a test before snapper season. i have changed the oil and filter and i thought that had fixed the problem until a trip or 2 later when it started again. yesterday i snipped the high pressure sensor wire(yellow/ red) and grounded it. today i took it offshore and got the same thing. if you go full throttle from the beginning it will do it immediately. if you keep it under 3000 rpm it may go for a minute without alarm or it may go 5 minutes before the alarm sounds again. If you rev the engine in neutral it will give you the alarm as well and the light goes out. i was under the impression that only the high pressure and low pressure sensors would allow it to go into shutdown mode. trying to figure out how it keeps shutting down since i have eliminated both of those sensors. the reason I'm routing around these is for process of elimination and one or both of the sensors require you to remove the heads to replace. any ideas or extra info that i don't have will be greatly appreciated.
