PontoonLife
Hello,
Just trying to get the boat out for the first time this year and having issues with the trim/tilt. Everything was working fine last year. Left prop in trim up position, I know I probably should have left it down.
When hitting the up and down on the trim tilt the solenoids click but the trim motor makes absolutely no noise.
I took the trim tilt motor apart and without the hydraulic/oil chamber attached the motor spins just fine when the trim up/down buttons are pressed!
I tried taking a screwdriver and twisting the hydraulic/oil chamber device and I thought it was spinning just fine. Oil level in the chamber is normal.
Thinking that the motor was now working I put the motor back together and still I am getting the same results, the solenoids click but the motor does nothing. Frustrating!
Any suggestions on what I can try next?
See pictures for my equipment..
