MaxMalmgren
Hi,
It seems my 1978 500 was ready to fall apart just after I bought it - got a good season out of it, then at the end of the next season it started to act up. Next year it wouldn't start.
I identified the trigger as being faulty, swapped it out for a new one and I got spark on all cylinders now. I tried to start it, but it wouldn't, so I checked the fuel - lines were stiff and broken, so I bought new ones.
At the same time I took home the two carbs and cleaned them - lots of gunk in them, no wonder it didn't start. Took lots of pictures and notes, so I should have assembled it correctly. Didn't seem like too many mistakes were possible, except the order of the membranes / gaskets in the fuel pump. I think I got it right, but how do I tell?
When I put the carbs back in it fired right up after a second of using the choke, but it idles horribly. It revs up, to what I would say is more than idle speed, then almost dies, then revs upp again, then repeats. Sometimes it does die completely, but fires up with a bit of choke.
What could cause this?
Haven't been able to test it much since the impeller is shot, I think I need to buy a new housing and not just the impeller since the gaskets are falling apart.
So, two questions:
1. How do I tell how to put the fuel pump back together?
2. What could cause revving up, then almost shutting down completely, repeatedly while idling?
Thanks for any help
So, two questions:
Thanks for any help
