Results 1 to 4 of 4
    Default Canít get boat into neutral
    I recently acquired my first boat. It is a 1989 star line, and it has what I believe to be a 1972 evinrude 55 outboard on it. Took it to the lake yesterday and everything was going good until I realized I couldnít get it out of Forward, i could push the neutral and reverse buttons, but the prop keeps spinning forward.
    after cruising around for a little bit I tested out the buttons again. And I was able to shift it back and forth a few times, however eventually it got stuck in forward again, which is the way I ended up putting it on the trailer like that.
    Today, I cannot get the engine to start, I presume because I cannot get the engine into neutral. I had read a few posts, and I believe they refer to this shifter as a hydra electric shifter. It seemed like one solution was to wire in a toggle switch, does anyone else have any suggestions?
    Default Re: Canít get boat into neutral
ID:	21131Click image for larger version.
ID:	21132Click image for larger version.
ID:	21133Click image for larger version.
    Sep 2010
    19,066
    Motor has to be turning to get oil pressure to shift it.------Motor has to have ---TYPE-C ----gear oil marked for electric shift.-----Check lower unit for water in the gear oil.
    i do believe the shifting problem was indeed the incorrect fluid, i drained the fluid out and it was black and milky. I added the type C, and saw that it was green, so im assuming that the previous owner put the wrong stuff in there, unless theres a type C that would be black. Anyway i was concerned about the milky oil anyway, so i went ahead and drain the new oil after a couple trips, and yes it was milky as well. so i went ahead and bought some new fluid, as well as a pack of those rubber washers. I inspected the old washers and one of them had a fair amount of metal shavings embedded into it, so hopefully thats where the water was coming in. Going to take the boat out a couple more times, and check the oil again. I'll hope for the best.
    As for the starting issue, quite simply my battery was drained.
    Thanks.
  1. Bought the boat, no plug, boat filled w/ water. Now what? 1985 aq125
    By sonnyny in forum Volvo Penta Gas Engine Forum
    Last Post: 06-05-2010, 11:24 AM
  2. I loose neutral when boat is warmed up
    By riverdiver in forum Mercruiser Sterndrive Archive
    Last Post: 07-08-2009, 09:41 AM
  3. Cant get boat in to neutral
    By chicknhawk in forum Mercruiser Sterndrive Archive
    Last Post: 07-03-2009, 01:02 AM
  4. Boat went into neutral
    By justin_bourgeois in forum Mercruiser Sterndrive Archive
    Last Post: 10-03-2008, 11:41 PM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
