MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Results 1 to 2 of 2
    Romilius's Avatar
    Romilius Guest
    Default " I have a johnson 150 v6 salt
    " I have a johnson 150 v6 salt water outboard and im having great difficulty seperating the head from the midhousing to renew piston and rings, I have power head striped down, all studs and bolts removed and the gear linkage is disconnected.The seal is broken between the powerhead and the midhousing but it won't seperate!,what is normal procedure for seperation ?,am i not applying enough force? or am Ioverlooking something, any help with this would be greatly appreciated as it is really holding me up. thanks in advance. "
    Feb 2001
    10,711
    Default "Romilius.... Remove the lower
    "Romilius.... Remove the lower unit retaining bolts, then attempt to remove the powerhead, moving it up and down. If the lower unit moves up and down also, the driveshaft splines are frozen within the crankshaft splines. If which case, that's a mess! Sometimes one can free the splines by yanking the powerhead upwards, then having the skeg of the lower unit supported so that it can't drop, force the powerhead back down, gradually freeing the splines. Sometimes, the driveshaft has to be cut. Spraying penatrating oil at the splines might help. Sorry to say there's really no set cure.
    Joe[img][/img]"
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
  1. Yamaha 1994 200hp power head removal - help
    By mills in forum Yamaha Outboard Forum
    Last Post: 05-08-2010, 06:08 PM
  2. 02 DF 115 Power head Removal
    By bobh in forum Suzuki Outboard Archive
    Last Post: 06-19-2008, 12:32 AM
  3. 150 1994 Evinrude Power Head removal
    By ericv in forum Johnson Evinrude Outboard Archive
    Last Post: 02-17-2008, 10:24 AM
  4. Head removal 120 looper
    By dmt in forum Johnson Evinrude Outboard Archive
    Last Post: 12-26-2007, 07:31 PM
  5. 1982 35hp Johnson Power Head Removal
    By kenny in forum Johnson Evinrude Outboard Archive
    Last Post: 10-10-2003, 12:59 PM
