patrickjreynolds
I have a 1997 Baja Islander 232 with a 7.4LX EFI-MPI Bravo engine. Right after I purchased it I suffered vapor locking symptoms. I could run all day with no problem, but if I sat and idled for a few minutes it would die when I accelerated. Once I shut off it would not start until it cooled down for hours. I replaced the mechanical fuel pump then rerouted and insulated the fuel line away from the heat of the engine. This helped, however it will now just idle longer period (10 min or more) before dying on acceleration, and it will start up after sitting and then die when I accelerate. There is not excessive heat, I can grab the fuel line and the fuel pump and they are cool to the touch. I have discovered that if I break the fuel line at the Vapor Separator tank it releases the pressure and it starts right up. This is now my work around, I can start back up right away by releasing the pressure in the fuel line. I am unfamiliar with VST's, is the VST causing this problem? Any suggestions would be appreciated.
