Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default Audible Alarm Volvo Penta 5.0 GXI B
    When I turn my key on, not over....just turn the key on, my Audible Alarm starts BEEPING and will not stop.....The engine is not even started yet...Just turn the key on....I have started it and the beeping continues...
    I know that the manual states low oil pressure or high water temp....but ALL my gauges are reading just fine (normal)
    Does anyone have an answer?? I have just had a brand new, very expensive outdrive installed and have not even gotten to take the boat out for a ride!
    Looking for any help....any suggestions!!
  2. #2
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,173
    Default Re: Audible Alarm Volvo Penta 5.0 GXI B
    Don't know how this one is wired, however, a disconnected wire to an alarm sensor usually causes the alarm to sound. In your case, at least no oil pressure and high water temp. There may be others. Since you have no oil pressure when key is turn on but not started, an alarm condition is correct.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
  3. #3
    Quote Originally Posted by SuperSue View Post
    I have this exact same issue with my 5.7gl pefs. I assumed I had a bad temp switch because I was td to test ohms through it, and the switch read nothing. Got the new switch and it reads exact same. Alarm still audible continued beep beep but all gauges read fine. Beep starts before engine start and continues through engine run. It started out on the water and idle. Boat ran fine all the way back to the dock.
Similar Threads
  1. Audible Alarm
    By phildclark in forum Volvo Penta Gas Engine Forum
    Last Post: 07-12-2015, 10:42 AM
  2. volvo penta constant audible alarm
    By scooter098 in forum Volvo Penta Diesel
    Last Post: 12-29-2013, 09:22 PM
  3. Audible Alarm
    By MKDoWork in forum Mercury Mariner Outboard Forum
    Last Post: 01-29-2013, 09:40 AM
  4. audible alarm
    By wright in forum Volvo Penta Gas Engine Forum
    Last Post: 11-25-2011, 05:19 PM
  5. Audible alarm on my Volvo Penta 50 GI
    By gjgonzalez in forum Volvo Penta Gas Archive
    Last Post: 07-01-2009, 12:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
