Good evening,
We picked up a newer 2010 boat that was running with a 5.7 port injected motor with the catalytic converters on it, that the boat hull got wrecked in an accident. The hull and outdrive were both hurt badly, but the motor is fine. We have a 98 searay boat with Mercruiser 5.0 TBI with a cracked block and manifolds that has been sitting. ( plus never have been a fan of the TBI... Is it computer possible to drop the complete newer motor in the older boat an have it run? The newer one has a 14 pin connector on it. I read that there is a harness adapter that will change it over to the older 10 pin, but do not know if that is a actual solution that will work for this. Are there known issues that have to be addressed for any of the sensors due to the Updated exhaust and emissions. The 5.7 is completely dressed with all sensors and computer. Are there any other different sensors that the up front cluster ( horn) has to be able to distinguish. I’m aware of the gear ratio drive difference, but that change will be an easy swap if the motor will actually be able to run in the older boat.. Is this a doable swap?
Thank you for any help or suggestions on this.
