Today i finally got to put my 4.3 v 6 new rebuild engine on the water we have had it running with the hose and all goes well starts and runs also idles down fine goes into gear and reverse all systems seem to work put it into the lake today went out through the harbor just ran fine then we opened it up a bit to 2000 rpm and it started to back fire a bit it got no better after i tried to adjust the distributor . Knock it out of gear and it climbs to 2500 rpm without a miss and sounds good back in gear and it starts to miss fire or back fire around 1700 rpm . any thoughts of where i should start looking would the prop at a to great a pitch cause that. just hunting for clues thanks mike
