1970 85hp johnson V4
larry
" I've got this 1970 85hp
" I've got this 1970 85hp johnson V4 with spark on one engine bank . Could this be just a point or plug wire problem, or is it possible for the pack to partially break down? "
" Sparky the points are new, w
" Sparky the points are new, when you say rotor you mean the rotor button or (cap) right? I'm afraid you lost me on the vent housing can you explain it to me, I'm a novice with outboard terms. When you say test your refering to an ohm meter correct "
" Venthousing is the name give
" Venthousing is the name given in the parts book. Could be called a distributor cap. A good shop can test it with a mercatronic test unit. No spark on 2 cylinders , sure makes a set of points supect. "
