Warning horn. 96 johnson 90
Basmn
Can the warning horn in the throttle housing be converted to a light (DIY )...my hearing is shot and i need a visual warning.
I know about the system check available from omc but is there a quick way of a warning light install ?
From what i understand the horn is activated by ground. To wire in a light i think i would require a 2 wire bulb...one wire to power and the other T ed into the horn ground wire...does that sound right ?
