J
Joseph Czech
Guest
" I am having a problem with m
" I am having a problem with my 70 Hp tohatsu. I have recently taken off the carbs and cleaned them, replaced the plugs, drained the tank (after carb cleaning)and replaced water separator. Heres the problem. Yesterday I was driving out to the beach (about 5 miles) the motor started up and ran fine there. When I went to leave I had a problem getting it started. When I did i seemed as if one cyliders was not firing. It was spraying gas instead of try to suck it into engine. The only was it would stay running is with the Idle throttle at max. I finally put in new plugs and got moving enough to get to a ramp. I am getting good fire but it just doesn't seem to want to start after it has run for a while. Could I have gottem some trash up in the carb after I cleaned them but before I drained the fuel tank etc. any help would be appreciated.
thanks. "
thanks. "
