Results 1 to 5 of 5
    Default What water pump is this? And where do i get parts? Dearborn Intercepter 312 57
    Hi All
    I cross my fingers you guess can help, as i am getting nothing on google on this.
    I have a Dearborn interceptor 292 or 312 from 57 in an Arcangeli Super Jolly V8 form 62.
    Its overheating so i suspect i need to change the impeller in the waterpump.
    But i can not figure out what the water pump setup is called, or where to source parts for it.
    It says F-M-330 on it and F-V-306, but google shows a ton other other pumps. Not this one.
    Can you help me with what i am looking for and where to find parts.
    Anders Hjorth, Copenhagen
ID:	20901Click image for larger version.
ID:	20902Click image for larger version.
    Sep 2008
    Maryland - USA
    8,017
    Default Re: What water pump is this? And where do i get parts? Dearborn Intercepter 312 57
    http://www.marineengine.com/boat-for...s-for-1957-312
    the suggestion there is to swap over to a Sherwood....I'd expect you local sherwood dealer can go from there....if not, there are a few large sherwood dealers on the internet...
    Mar 2009
    Portland, Oregon,
    11,562
    Anders and Mark...... I must admit that I am very unfamiliar with this set up.
    I have a question: is this a flexible vane impeller pump, or is it a centrifugal pump?
    If flexible vane..... how on earth is a person supposed to gain easy access to the impeller area?
    Portland, Oregon
    The water pump was made by Interceptor and was called Dearbo Water Pump. It was not made to lift water but to circulate it up to the motor. It is a centrifugal pump and made with Ford circulating pump parts. It was replaced with Sherwood pump M10280G (RH) or M10270G (LH).
    I have purchased a steel bearing pump from TSC or Orshlands and modified the pump to Wark great. On my 6cyl interceptor.
  1. Late Dearborn Intercepter engine for sale
    By 1hot57 in forum Ford Interceptor Marine Engine Forum
    Last Post: 02-05-2018, 04:43 PM
  2. Raw water pump/parts for 1957 312
    By BrennanJ in forum Ford Interceptor Marine Engine Forum
    Last Post: 06-13-2014, 08:56 AM
  3. Can you still get water pump parts for a m60a
    By temple1975 in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-16-2009, 08:24 AM
  4. 20 hp water pump kit xtra parts
    By dogditcher in forum Mercury Mariner Outboard Archive
    Last Post: 09-15-2007, 06:39 AM
  5. Parts source for water pump kit
    By snookwhaler in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2007, 06:59 PM
