Results 1 to 4 of 4
Thread: 74 starcraft
  1. #1
    Default 74 starcraft
    Just bought a 1974 starcraft that was gutted to redo. The previous owner just cut wires, looking for a wiring diagram for the boat over all. Thanks in advance.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,990
    Default Re: 74 starcraft
    Highly unlikely you will find it.....best thing to do is to sketch out what you have and then fill in the interconnect details and then do it....
    FWIW is always a prudent idea to use quality marine grade wiring and to follow the ABYC color code...
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,887
    Ayuh,..... That Ain't gonna happen,......
    Map out yer own wirin' diagram,.... that's the only way you'll have one,.....
  4. #4
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,649
    Agree with Makomark and Bondo. Be sure to use tinned marine wires and shrink-wrap connectors. Both are available from West Marine or Jamestown Distributors.
    Map it all out first. You should install a master battery selector switch with two batteries - one dedicated to cranking the engine and the other "house battery" for running equipment. Use a panel of fused switches on your console. Run 8 AWG wires from the common battery grounds, and one of the positive terminals from the battery switch (house battery) to the fused panel and run everything up front off of that. Do not run anything except gauges off of the key switch. Run all of the wires through a PVC sleeve installed up under the starboard gunwale.
    I'm somewhat of an amateur, but have completely rewired three old boats. It is not difficult to do, but takes time, the right wire, the right connectors, and a good stripper/crimper. Tag every wire with where it comes from and where it goes. That will save you a ton of time in the future when something electrical stops working, which it will, eventually.
    CHawk 25 DLX
Similar Threads
  1. Starcraft BV 170 - Flooring
    By VinceM in forum Johnson Evinrude Outboard Forum
    Last Post: 04-20-2018, 12:02 AM
  2. Starcraft Transom Corner Cap
    By earlbuddy in forum Boat Hardware
    Last Post: 09-17-2014, 07:10 PM
  3. 1973 starcraft capri 120 GM 153 I/L4
    By momjones in forum Mercruiser Sterndrive Forum
    Last Post: 07-01-2013, 01:02 AM
  4. 1987 starcraft 2.3 ford
    By starcraft classic in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-26-2011, 07:44 PM
  5. 1977 starcraft 165 omc
    By tim_j in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-03-2007, 12:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
