Click for Crusader parts and manuals!
Results 1 to 22 of 22
  1. #1
    Default Crusader 454 1989 runs for 5 seconds then quits.
    My starboard engine starts and runs only about 5-7 sec. before shutting down. The oil pressure sending sensor was replaced last year. I'm showing good oil pressure, could I have a choke stuck or float stuck? Any ideas??? Also, what carb does it use or how to identify?
  2. #2
    Default Re: Crusader 454 1989 runs for 5 seconds then quits.
    Check your fuel pressure/fuel filter. Carb should be a Rochester Q-Jet, should run off of approximately 8-10psi.
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    2X on the qjet - qjets are unique - the internet is your biggest source of free informati
    they operate best with 4-6 psi....most won't handle 8PSI very well.
    will it restart right away??? what's coming out of the exhaust?
    flooding are usually easy to detect with your nose.....is there any fuel in the sight tube?
  4. #4
    Quote Originally Posted by makomark View Post
    It will not restart right away. I do smell a slight gas smell from the exhaust making me think it could be a stuck choke or float. It's hard to do with one person. As for sight tube I don't see one in there.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    Quote Originally Posted by sailawaysg View Post
    ...... As for sight tube I don't see one in there.
    That's not good - the sight tube is the yellow tygon tube that runs from the front of the carb down to the fuel pump....as it ages, it will become brown and inflexible. Its purpose is to dump any fuel from a ruptured diaphragm into the carb (vs letting it fill the bilge with gasoline)….
    most big blocks, w/ qjets, suffer from 'nozzle drip' at idle and have a tendency to run a bit rich from it. a stuck choke or a bad float will usually cause an easy to observe flooding condition...when it quits, pull the flame arrestor and see if the top of the carb is wet, especially around its perimeter....
  6. #6
    OK. I'm going to check on it shortly. Thanks!
  7. #7
    I think I may have a wiring connection problem with the oil pressure shut off switch. One is N/O, N/C & C. One has a fuse inline which is good but the rest of that wire is suspect. I just thought of this and wonder what I should read on the 3 conn. with a meter?
  8. #8
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    you should have a mechanical pump on an 89 block....has the block been swapped for something newer?
  9. #9
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    Do you still have the Mallory distributor with the points inside?
  10. #10
    The way your system is wired, while the starter is cranking the fuel pump is receiving voltage to start the engine. As soon as the oil pressure comes up line voltage is directed to the pump to keep the engine running. Sounds like your pump is running during the start cycle but drops off when you come off the starter. Oil pressure switches are very problematic. Recommend you monitor voltage going to the pump immediately after the engine starts. Best place to connect you multimeter is at the fuel pump circuit breaker. Good Luck.
  11. #11
    Thanks!
  12. #12
    I believe the engine was swapped. I see the pressure sensor and 3 wires. 1 looks like it goes to the fuel pump (electric).
  13. #13
    One wire goes to the pump, one wire goes to the ignition switch starter circuit, and the last wire is battery/alternator voltage. At rest, the pump and ignition wire are spring-loaded closed. When oil pressure comes up, the pump wire is disconnected from the ignition source and connected to the battery wire. I had a new pressure switch fail in six months ($110 - ouch). They are famous for poor reliability. Might ensure that the battery voltage wire is hot at the pressure switch with the ignition switch on.
  14. #14
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    The NC side of the switch controlling the fuel pump is usually connected to the START side of the ignition switch . the fuel pump is engaged when the starter is active.....making that conection from the switch to the IGN lead would defeat the intended 'safety feature' of using the oil pressure controlled switch...
    And, wih the update that this really isn't a markIV block, you can debug the fuel pump partially by just bypassing the control circuit using a fused jumper to control the pump. if that keep the engine running, then you need to figure out what has gone bad in the control circuit that was implemented when the block was swapped.
  15. #15
    Update: No gas to carb. now. Ran out of gas and put 30 gals. in 300 gal. tank. Do I need to prime the electric fuel pump? Could the breaker be tripped? I'm at a loss...
  16. #16
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    does the fuel pump run if you jump it to battery voltage?
  17. #17
    If wired correctly and working -- put the trans in gear and turn the key to start. The fuel pump should run to prime the system without the starter running.
  18. #18
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    I think that will only work with the MEFI controller on the injected models.....the carb/electric fuel pump wiring is different....
  19. #19
    Works all the time with electric fuel pump/carbed engines. Just need to be sure the neutral safety switch is functional to avoid starting in gear.
  20. #20
    Quote Originally Posted by Mulletwagon View Post
    I'm going to try that this morning. Thanks
  21. #21
    PROBLEM(s) SOLVED!!! Bad fuel pump AND points...
  22. #22
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,026
    glad you're running again...
Similar Threads
  1. Indmar assault 325 - takes 3 seconds to 9 seconds of cranking to start, runs perfect otherwise
    By makesumwake in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 02-21-2018, 04:48 PM
  2. 5.7 litre merc runs for 20 to 30 seconds then quits
    By supernill in forum Mercruiser Sterndrive Forum
    Last Post: 08-04-2013, 04:16 PM
  3. Nissan 6 HP runs for 5 seconds
    By sparkypks in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-30-2011, 10:28 AM
  4. 1990 Force 90 hp quits in 10 seconds
    By BaylinerBill in forum Chrysler Force Outboard Forum
    Last Post: 01-21-2011, 08:37 AM
  5. 2002 50 litre starts right up then quits abruptly in 1020 seconds
    By 202br in forum Mercruiser Sterndrive Archive
    Last Post: 06-14-2009, 10:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
