Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default Crusader 270hp Divorce choke Thermastate
    Had to replace my divorced choke thermastate on my Rochester quadrajet. I am having problems with it working properly. Are you suppose to adjust these or are they good to go out of the box. After running boat for awhile I try to restart engine and I cant due to chock keeping butterfly closed. Need help
    Thanks Mike
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,190
    Default Re: Crusader 270hp Divorce choke Thermastate
    they usually need to be adjusted.
    make sure the 'can' (or housing) is not binding up the assembly - the butterfly should move over its full arc with modest finger pressure...
  3. #3
    Join Date
    Apr 2009
    Location
    Long Island, NY,
    Posts
    180
    They can be adjusted by bending the rod that connects them to the choke linkage.
Similar Threads
  1. Crusader 270hp Stalls below 1800rpm
    By FastFred in forum Crusader Marine Engine Forum
    Last Post: 02-14-2014, 06:36 AM
  2. Crusader 1989 carb 270hp rough idle
    By makomike1 in forum Crusader Marine Engine Forum
    Last Post: 08-23-2012, 08:47 AM
  3. CRUSADER DWELL ANGLE 270HP
    By otsquare in forum Crusader Marine Archive
    Last Post: 06-13-2009, 10:54 PM
  4. 1984 OEM Breakdown on Crusader Engine 270hp
    By gastite in forum Crusader Marine Archive
    Last Post: 12-27-2007, 02:50 PM
  5. Crusader 270 %3d 270hp
    By mikew in forum Crusader Marine Archive
    Last Post: 12-06-2005, 02:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
