mercury force 90 hp cooling
Jayce
I just replaced the water pump and there is water coming out around the shifing level, is that right?
there is water coming out the small hole on the side of the cowl, but not the 3 holes in the back.
Year?
Pics helps.
The small hole might be the pee tube, it operates to show you the water's pumping.
The water at the shift spot, it shouldn't have water.
Pics and the year helps.
