A number of Yamaha 9.9 4 stroke hi thrust owners have added an external voltage regulator ... specifically a Flexcharge NC25A . I would also like to add a regulator that works.
Most problems people have is with over voltage after the batteries are fully charged. They add an "additional" regulator to the output of the engine. However, my problem is that I suspect the factory regulator gets hot and shuts down... mine just quits charging... I also suspect the factory regulator has ruined at least two batteries that were new..
I have run the existing engine output to my electrical panel and installed an ammeter. I can monitor voltage and amperage. What I would like to do is run an UNREGULATED electrical output from the engine using this cable lead that I have installed ... then I would be able to install a good regulator.
HOWEVER, the factory regulator is also a rectifier. (I was told a rather questionable quality half wave rectifier at that)...
I see that on the yamaha 9.9 electrical schematic of the engine there are two leads (green and green with a white stripe) coming into the engine regulator from the "Lighting coil" of the engine alternator. .. I have to assume these could be used to fit a bridge rectifier on the engine..?? But, there is also a third wire from a second coil on the engine from a coil also marked "lighting coil"....
I doubt anyone will read this thread or if they do will have gotten this far LOL ... but I am determined to fix the regulator problem I've had with this engine from day one. I assume that if I were to connect a full wave bridge rectifier that I could run the unregulated output to a separate Flexcharge regulator ...
If there is anyone who might 1) understand what I am trying to explain and 2) have some idea of how to connect an external voltage regulator AND rectifier, Please contact me ... [email protected]
